Headlight Low Beam Bulb
MJ23
Is it that easy to replace a headlight low beam bulb on a RX 300? I couldn't find any information about it on the internet.:pirate:
Rotate the back of the bulb housing a partial turn and pull out. Pop out the old bulb, (has a clip that holds it in - look at it and the new one to figure it out) - put the new bulb in (do not touch the new bulb with your fingers or any other greasy object or it will shorten life). I use a napkin. Reinsert into the housing and rotate it back so that it is snug. Only problem I had was that the cords were a bit short so was tight manuveuring - but not difficult. Took longer to clean dirt off hands than to replace the bulb.
