droppedlexus Posted August 17, 2006 Share Posted August 17, 2006 ok I have seen this topic discussed a few times but no definate answer,......here is my problem I notice a couple of months ago that my center console would shut off. Now what I notice is this If my center console is "acting up" and I turn the key " not starting the car" but turning the key enough that the radio and AC and clock should turn on "they don't" but the rest of the electronic compnets work fine...now I assume that my battery should kick in at this point, since the car is not started can I assume that this problem is not my altenator? I beleive this problem could be a bad ground, because this seem to start happening after I had an aftermarket radio put in. also one more thing if I turn the car on and the center console is working ie "AC and clock" once I turn the radio on everything starts to mess up.....even if I turn the ac off the radio still fails to function properly... Quote Link to comment Share on other sites More sharing options...
Fidel Castrol Posted August 20, 2006 Share Posted August 20, 2006 Sometimes it's as simple as a blown fuse that handles the center dash components (A/C, radio, clock, temperature). Quote Link to comment Share on other sites More sharing options...
Lex01_430 Posted August 25, 2006 Share Posted August 25, 2006 i had a similar problem...was actually a loose cable to the battery. the connection looked good but was loose. i'm not convinced that it would be a fuse because i've never seen a half working fuse...g/l Quote Link to comment Share on other sites More sharing options...
