LUKE a MANIA Posted August 9, 2006 Share Posted August 9, 2006 The trunk button inside my car won't open my trunk... i have to use my key to open it... is there a fuse or some kind of thing that would fix it? Quote Link to comment Share on other sites More sharing options...
lexus082 Posted August 9, 2006 Share Posted August 9, 2006 Check the fuse marked "Door". Then to check the trunk lid opener motor connect a positive 12 volt source to the opener motor connector and then a negative lead to the body of the opener. Do not hold positive lead onto opener motor connector for more than one second. Manual states: "Perform inspection in a short time (within 1 sec). So just make contact with the 12 volt source and the opener motor connector and remove the 12 volt source as soon as you make contact. I would check those two things first. Check fuse and then perform test to see if the trunk lid motor is working properly. If you don't understand let me know and I will re-word it. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 10, 2006 Share Posted August 10, 2006 Did you try making sure the trunk lock out button in the glove box is not pressed? Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted August 12, 2006 Share Posted August 12, 2006 Did you try making sure the trunk lock out button in the glove box is not pressed? I have just the opposite problem..my trunk opener inside the door will work..but my key for the trunk will NOT work..? Thanks for any help!!!! Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 12, 2006 Share Posted August 12, 2006 When i read you reply to this thread "air force" do you notice you say it does not work but give no details of what does not work? It does not turn ,the key won't go in , it just keeps turning. No detials = no clue Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted August 13, 2006 Share Posted August 13, 2006 When i read you reply to this thread "air force" do you notice you say it does not work but give no details of what does not work? It does not turn ,the key won't go in , it just keeps turning. No detials = no clue Sorry bout' that...the key will go in fine and I can turn it..but it will not release...Thanks... Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 14, 2006 Share Posted August 14, 2006 No problem, Does it turn all the way ? Is there resistance near the end of the turn with the little give that usually releases the latch? I would suggest pulling back the liner and seeing if the rod and fallen off from a broken clip. Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted August 14, 2006 Share Posted August 14, 2006 No problem, Does it turn all the way ? Is there resistance near the end of the turn with the little give that usually releases the latch? I would suggest pulling back the liner and seeing if the rod and fallen off from a broken clip. Looking at the key it goes in straight up..when you turn it it turns to the 2 o'clock position and stops... Quote Link to comment Share on other sites More sharing options...
Air Force Rascal Posted August 14, 2006 Share Posted August 14, 2006 No problem, Does it turn all the way ? Is there resistance near the end of the turn with the little give that usually releases the latch? I would suggest pulling back the liner and seeing if the rod and fallen off from a broken clip. Thanks SK for your help..I found the problem and fixed it..the Rod was a little sticky on the slider..I sprayed some WD40 on it and it's working fine now...thanks again.. Quote Link to comment Share on other sites More sharing options...
