latintxn54 Posted August 4, 2006 Share Posted August 4, 2006 Anyone out there ever remove the crankshaft sprocket, which is mandatory prio to replacing the seal? I've got the official Lexus repair manual on CD as well as other resources off the internet which explain using a SST tool for removing the sprocket but that tool's impossible to find. Even the local Lexus dealers won't rent the tool. I'm hoping someone out there has been thru this experience as I am ready to replace the timing belt, water pump & idler pulleys. I'd like to do the 2 camshaft seals which seems pretty straight forward and requires only a harmonic-balance-type-pulley tool to remove the camshaft pulleys. It's the crankshaft sprocket that's a concern. Perhaps someone's got an alternative tool. Thanks for any replies. V. Gonzalez Quote Link to comment Share on other sites More sharing options...
wandawoods Posted August 4, 2006 Share Posted August 4, 2006 Anyone out there ever remove the crankshaft sprocket, which is mandatory prio to replacing the seal? I've got the official Lexus repair manual on CD as well as other resources off the internet which explain using a SST tool for removing the sprocket but that tool's impossible to find. Even the local Lexus dealers won't rent the tool. I'm hoping someone out there has been thru this experience as I am ready to replace the timing belt, water pump & idler pulleys. I'd like to do the 2 camshaft seals which seems pretty straight forward and requires only a harmonic-balance-type-pulley tool to remove the camshaft pulleys. It's the crankshaft sprocket that's a concern. Perhaps someone's got an alternative tool. Thanks for any replies. V. Gonzalez this thread might help you: http://us.lexusownersclub.com/forums/index...showtopic=26997 Quote Link to comment Share on other sites More sharing options...
