REHBEAVIS Posted July 29, 2006 Posted July 29, 2006 Had to make a hard stop. The check engine light and VSC lights came on. Went to auto zone and the analyzer shows a code P1135. Any ideas regarding repairs, etc.? Vehicle is a 2001 RX300 AWD with 71,000 miles. Runs fine. Tried resetting lights but they come right back on. Replaced gas cap.
halkow Posted August 21, 2006 Posted August 21, 2006 Had to make a hard stop. The check engine light and VSC lights came on. Went to auto zone and the analyzer shows a code P1135. Any ideas regarding repairs, etc.? Vehicle is a 2001 RX300 AWD with 71,000 miles. Runs fine. Tried resetting lights but they come right back on. Replaced gas cap. P1135 sounds like a oxygen sensor.
lbintab Posted September 5, 2006 Posted September 5, 2006 did you have your oil changed lately? when they check the air filter the hose thats behind the air box sometimes gets disconnected. check it out. almost sure thats it.
Bob GX Posted September 6, 2006 Posted September 6, 2006 Ditto the comment on checking the vacuum hose behind the air filter box. I had the same problem on mine (2002 RX), right after I checked the air filter. Use a flashlight and look carefully, it's a little hard to see, and it was a bit of a tight fit to reach behnd the box and put the hose back on the fitting. Only thing I would add, if I remember correctly, I had to disconnect the battery for a few minutes, and then reconnect, to get the Check Engine and VSC lights to go out. My car always ran just fine. Drove it that way for a week because the Lexus dealer is 50 miles away and a special trip to get down there. I had an appointment to get it checked, and the service writer said it was not going to harm the engine to drive it that way. Then I found out about this hose problem causing those lights, and fixed it myself.
steviej Posted September 8, 2006 Posted September 8, 2006 P1135 sounds like a oxygen sensor. Correct, P1135 is Air/Fuel Sensor Heater Circuit Malfunction for Bank 1 Sensor 1. This is the pre-cat O2 (also called AF) sensor between engine and firewall. steviej
Lukus5 Posted July 27, 2008 Posted July 27, 2008 Thanks to this posting I was able to save and solve this simple problem after the oil change and air filter removal. I want to emphasize the point that the battery must be disconnected to reset the check engine light. After this repair I went underneath to get fimilar with the car, and I saw a hose tube coming from the center what appears to be the transmission. This tube connection was not attached to a hose and I could not find one either. I would like to find access to the exploded views of the RS 300 models. Does anyone know where I can find access? I am certain the dealers have access and may ask about the tube issue at my locate dealer. I do not think it is a drain tube and the check engine light is not on now. The tube fitting appeared to have a tube because it looked clean and had marks that looked like a hose may have ben removed during the oil change. I must add the area around this hose connect was very clean anyway, so I may be worring about a drain/vent type connection. Again I thank you all that post and help others with their fine Lexus cars and SUVs, solve issues that many of us can follow.
JimRI Posted August 19, 2008 Posted August 19, 2008 did you have your oil changed lately? when they check the air filter the hose thats behind the air box sometimes gets disconnected. check it out. almost sure thats it. Right ON... Yes it was disconnected.. Yes that fixed it... Thank You.
crasshh Posted November 20, 2008 Posted November 20, 2008 did you have your oil changed lately? when they check the air filter the hose thats behind the air box sometimes gets disconnected. check it out. almost sure thats it. I did have a oil change and a little while later "Check Engine Light" HUNH, Cheers, Cheers. This worked perfectly. I first clicked the gas cap again. Just to make sure. Then I checked behind the filter and there she was hanging around not attached to anything. Like a nerd at a high school prom. Attached the hose back to the airbox,then tackled the fuse box. The fuse #13 would be under the hood as well close to the airbox and hose area. Took out the fuse waited for about two minutes then re-attached. Crossed fingers, put key in the ignition turned and hooorrray, no Check engine light. Note: During this whole process the car key should be in your pocket as a reminder not to have it in the ignition. Thanks for the tips. Much appreciated. The dealer would have had me spend an obscene amount of money for something you could do for almost nothing. Two Honks for the tips.
damagedude Posted November 25, 2008 Posted November 25, 2008 Same thing happened to my wifes 2004 rx330. Had oil change and then the next day, check engine, vsc, and trac off came on. Followed the directions here and no more lights. Just an FYI for everyone, if your hoses are loose, there will be two exposed points behind the airbox directly beside the silver engine cover. My hoses had fallen below so I missed it at first. Thanks again to this forum and post for saving me some dinero!
the_ian_crowd Posted January 12, 2009 Posted January 12, 2009 Thanks! The hose behind the air filter fixed my 2002 RX 300. It apparently was disconnected the day before during an oil change.
i0C Posted July 27, 2009 Posted July 27, 2009 did you have your oil changed lately? when they check the air filter the hose thats behind the air box sometimes gets disconnected. check it out. almost sure thats it. This worked like a charm for me. Glad this forum and your post was easily accessible via a quick google search. First hit!.
Salinger Posted April 21, 2010 Posted April 21, 2010 did you have your oil changed lately? when they check the air filter the hose thats behind the air box sometimes gets disconnected. check it out. almost sure thats it. Good call! I just had my oil changed and the VSC light and the engine icon/check light came on. I checked the manual and all it said was to go to a dealer. I thought it was something wrong with the skid control system, which sounded like big bucks. Glad I checked this website. I had just had my oil changed, and of course they pulled the air filter and tried to sell me a new one. When I got home I lifted the hood, and sure 'nuff, there was a hose disconnected behind the air filter box. I reconnected it, disconnected the negative battery cable for a minute, reconnected it, and the problem is gone. Thanks.
mrzukes Posted September 27, 2010 Posted September 27, 2010 This forum is great. Followed the suggestion(s) and it worked. Checked for the loose hose....made sure to check gas cap...and disconnected battery (negative line) for about 2-3 minutes. Turned the key and the lights went away.
Mitch3 Posted November 26, 2010 Posted November 26, 2010 This just happened to me a few hrs ago. Fortunately I have an honest mechanic. He suggested that it may be just loose gas cap (!). Shocking, but it was not fully closed (my 4yr old son helping me to put gas). Within less then 1 minute, all good. :)
StuL Posted February 4, 2011 Posted February 4, 2011 Same issue with my 2007 rx 350. Took it to toyota dealer for oil change and air filter since they are closer and cheaper. Thanks for this post, saved me big trip to Lexus dealer and how many $$$
smkrat Posted November 13, 2015 Posted November 13, 2015 Thank you for all the posts here. It really helped me. I have a 2001 RX300. The check engine and VSC lights appeared on my dash last week. I took my car to the dealer and they told me it was a fault sensor and the cost to repair was $600+. They said it was not necessary to replace. So I looked at the posts here and reset the lights, only to have them come back on. The one thing I did not try was taking the gas cap on and off. Last night, I filled up my car with gas. The “Check Engine and VSC” lights were on. This morning, I turned the car on and they did not come on. They did not come on after some lengthy driving today. There must have been air in the fuel line. Next time I will try all recommended solutions.
