Brake Noise
SARX
My 2000 RX 300 has noise like brake pads are worn out. I have personally taken the tires off
and inspected the pads and rotors. I still have lots of pad and the rotors are smooth.
Any ideas?
Do you know what type of pads are on the vehicle? I made the mistake of putting cheap $20 pads on mine from autozone and wound up using the money I saved on lots of aspirin from all of the sqeaking. OEM pads are a lot more quiet and they can be purchased from the local toyota parts department.
If you are already running ceramic pads (OEM or aftermarket) then definately follow Benjamins post above. If you are not using ceramic pads I would suggest you invest in some. They are quieter and less dusty then semi-metallic.
