Do I Really Need Toyota Brake Fluid?
spta97
I'm going to bleed the brakes on my GFs RX300 this weekend. Do I really need to get the brake fluid from Toyota or will the Prestone DOT 3 / DOT 4 work fine?
I tend not to buy into the hype of the dealers with their "special" fluids, but I want to do the right thing here.
Thanks!
Thanks. Dot 4 wouldn't be better?
I put ATE Superblue into my RX for over one year, a DOT 4, no problem.
User's Manual calls for DOT3 if you follow everything to the letter. Brake fluid is mainly a hydraulic fluid that can resist high temperature and DOT 4 is nothing but DOT 3 with higher standards (e.g. dry, wet boiling point). Just don't put DOT 5. Here is a good link
http://www.gs610.com/abc.htm
I like ATE because it has a blue dye, make flushing so much easier since you know when the old fluid is 100% gone. Next time I want to flush, just use ATE fluid with gold dye, same chemical composition, just different dye.
