Repaire In Toronto
Well it is time for my ES 300 1992 to get some repaire done...
I know for sure about :
Valve Gasket(s)
Suspension
Brakes
Spark plugs ( I changed front once, buit could not reach all at the back)
Would someone from Toronto area recomend INOVATIVE and CREATIVE MECHANIC to do the job ( referably close to North York, Richmond hill area. I feel LEXUS overcharging and trying to do far more than what is needed for car.
Please reply through the forum or directly at gefter@netzero.net or 905-881-3552
with many thanks,
Gennady
:geek:
Then how do you know something needs to be done to your suspension?
Well, Because I know car good enough to suspect problem during the ride while hearing different noises. Changing the valve gaskets is obvious and I could not reach all spark plug to change.
As well as front breaks need to be done.
I will REALLY APPRECIATE the lead to a GOOD RELIABLE HONEST MECHANIC!!!
I am trying to figure out if you need to have it worked on at a shop with a hoist or if one of the techs i know can repair it on his own with minimal tools.
With only basic information that you have provided it is very hard to evaluate.
