i got a new IS 350 with Mark Levinson aduio system two weeks ago....i noticed the rear speakers with crackling/static noise when sytem is on volume level around 25.....it happens when playing in all modes (radio FM, radio AM, CD, and ipod). i have tried to adjust the base, treble, and mid range, and also tried to adjust the balance and fade......but no luck. Please advice if you have any insight.
Thank you very much......much appreciated.
I have an 06 es330. Had the same problem from right door. Speaker had to be replaced.
  • 1 month later...
The speaker rubber or paper cone could be cracked. You would probably need to replace it or have it reconed, but reconing... not the best option. Good luck!
