smasood Posted June 26, 2006 Share Posted June 26, 2006 Hi, After installing the needles in the instrument cluster - the temp sensor needle has lost its correct position and now it shows more than half when the car is warm & also the resting position has changed from bottom to 1/4th up. How should I fix the orignal position of needle so it shows me correct temperatues. Thanks. Quote Link to comment Share on other sites More sharing options...
godfather18 Posted June 27, 2006 Share Posted June 27, 2006 Hi, After installing the needles in the instrument cluster - the temp sensor needle has lost its correct position and now it shows more than half when the car is warm & also the resting position has changed from bottom to 1/4th up. How should I fix the orignal position of needle so it shows me correct temperatues. Thanks. Pull it back off and put it back on, you put it on wrong Quote Link to comment Share on other sites More sharing options...
