wendy_94ES300 Posted June 16, 2006 Share Posted June 16, 2006 I noticed there is oil leak for my car for a while in the parking lot. When i brought my car to check for a/c service, i was told the valve cover gasket(front) need to be replaced. Is it supposed to be replaced when i do timing belt replacement? Or it is a seperate part. What else do i need to replace when i asked them to replace the valve cover gasket? thank you for your comments. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted June 16, 2006 Share Posted June 16, 2006 Seperate. The front gasket is actually easy to do it yourself. You need a 10mm socket & wratchet. Once you take the ignition coils & the little plastic engine cover off (Allen wrench, I forget maybe 5, or 7mm). The valve cover is only held on by 8x 10mm bolts. Take it off, throw the old gasket away, clean the surfaces with rubbing alcohol to get all the oil off the surfaces. Installation is the reverse of removal. :) You're asking why I just told you to do it yourself. 1) it'll take you an hour 2) the gasket is about $12 by itself VS they're gonna charge you an hour, or two of labor + the gasket. 3) i remember you... you're cool like that lol! Quote Link to comment Share on other sites More sharing options...
wendy_94ES300 Posted June 16, 2006 Author Share Posted June 16, 2006 Thank you very much. I will try to do it by myself then. Does someboy have pictures to show the steps and the position of the gasket? Seperate. The front gasket is actually easy to do it yourself. You need a 10mm socket & wratchet. Once you take the ignition coils & the little plastic engine cover off (Allen wrench, I forget maybe 5, or 7mm). The valve cover is only held on by 8x 10mm bolts. Take it off, throw the old gasket away, clean the surfaces with rubbing alcohol to get all the oil off the surfaces. Installation is the reverse of removal. :) You're asking why I just told you to do it yourself. 1) it'll take you an hour 2) the gasket is about $12 by itself VS they're gonna charge you an hour, or two of labor + the gasket. 3) i remember you... you're cool like that lol! Quote Link to comment Share on other sites More sharing options...
Toysrme Posted June 16, 2006 Share Posted June 16, 2006 Really the gasket is a "it'll only go one way" type of thing. Check that repair manual you got last time. My engine is alittle different, but basically. 1) You take the wires & hoses off the front valve cover that are in the way 2) You unbolt ithe valve cover & pry it up (Note, Toyota was smart when they made the engine. They installed a 10mm allen bolt in the top of the valve cover so that you can pry the valve cover off without muh effort!) 3) You'll have just the very front part of the engine taken off (I had alot more off in this pic, but that isn't a concern for you). This to this Quote Link to comment Share on other sites More sharing options...
godfather18 Posted June 16, 2006 Share Posted June 16, 2006 Mine has a svery small leak as well, should I put the new gasket on without any sealant and how much psi should put on the bolts when I put the cover back on. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted June 16, 2006 Share Posted June 16, 2006 Steel bolt into aluminim, 14lb-ft of torque. I.E. not alot. Ya, you need a little sealer around where the cam goes. RTV. Quote Link to comment Share on other sites More sharing options...
coleycoleman1906 Posted July 17, 2006 Share Posted July 17, 2006 What did / do you clean the valves with? What do you clean when you open the valve cover? Or do i just replace the gasket and leave everything else alone!? Quote Link to comment Share on other sites More sharing options...
