lexus082 Posted June 16, 2006 Share Posted June 16, 2006 I know what most of you are about to say if you viewed the topic. I know your only supposed to put Toyota Type TIV in the sc400 transmissions. Tonight I just removed the pan and cleaned the filter and magnets and filled up with Toyota Type TIV fluid. But I did not have enough Type TIV fluid to completely top-off. So I looked at the Valvoline transmission fluid bottle and it says it will work in Toyota/Lexus that require Type T IV fluid. I topped off using the Valvoline Dextron III and I just wanted to hear your thoughts on this. I intend as I was before only using the Toyota Type T IV fluids. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 16, 2006 Share Posted June 16, 2006 well if it is written that its compatible then it should be ok. Quote Link to comment Share on other sites More sharing options...
lexus082 Posted June 16, 2006 Author Share Posted June 16, 2006 well if it is written that its compatible then it should be ok. Thanks JZZ30. I will still stick with the genuine Type T Fluid. :) Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 17, 2006 Share Posted June 17, 2006 thats always a good thing to do Quote Link to comment Share on other sites More sharing options...
