How To Change The Map Light In An Is 300?
NSTY IS
Does anyone out there know how to remove the plastic cover off the front map light in the 2002 IS 300? The light blub is loose up there, but I can't seem to figure out how to remove the cover, and I don't want to break it. Any help would be great.
Chris
Springfield, VA
02 IS 300
98 ZJ
88 XJ
Take a table knife or something thin and wide like that. Put it barely the least bit under the gray bezel toward the rear and pry down gently. You'll be pulling down the housing and not just the lens. Once you get it down you'll see how it goes back on. Insert prongs at the front and swing the housing up till the clips at the rear click in.
