maxed_out Posted May 31, 2006 Posted May 31, 2006 Hey all. I was kinda getting tired of seeing the back end on my 91 droop more and more with each passing day. So I checked it out with a spray bottle of soapy water and the left rear air strut had a small leak. Just to let you know that I'm not totally off the deep end, I ordered a new (used) one. So waiting for it to arrive, decided to try out the ole green slime-you know the stuff for tires. I took off the strut and held it horizontal and added some green slime. I took the strut and rolled it around to move the slime inside to coat everything. I did 2 small applications and the stuff went right in. I used the air connection from the suspension sys to pump up the strut and seat the slime. Seat the slime boy that sounds weird. Anyway, put it all back together and shes still holding with no leaks. Will report results until the new one comes. I dont think this is wise nor I dont think its a long term solution it may just buy a week or so. In case you need the link to green slime its here. http://slime.com/customercare/viewfaq.php?id=30&q= No I dont work for them, just thought I'd share my tale with you. It may just work because I'd guess that system runs on lower pressure high volume type setup. I'll try to take a picture of the strut next time because I think you will see where the whole problem lies for these fine systems. The rubber boot wont allow the water in the wheel well out properly-it gets trapped against the strut. I'm guessing that here in the noreast with all the salt in winter that the rust does these things in. Happy trails.
SKperformance Posted June 1, 2006 Posted June 1, 2006 Never heard of it before , sound like a good product. It would be interesting to see how long it could repair your air strut before it leaking again.
maxed_out Posted June 1, 2006 Author Posted June 1, 2006 Hey overnight update. woke up and checked. still holding air. no droop. got a road trip today which should give it a good workout and will report results. also got new rotors (off ebay-non oem) installed and will post those results too.
CUMan Posted June 2, 2006 Posted June 2, 2006 This was real creative thinking. I have used this material for several years to stop slow leaks in lawn mower tires. It handles this very common problem with ease. A few ounces of Green Slime in each tire, and your leak is usually fixed permanently.
maxed_out Posted June 2, 2006 Author Posted June 2, 2006 Update...300 mile roadtrip yesterday. Lots of bumpy roads. No issues. New one not here yet which is fine with me right now.
maxed_out Posted June 29, 2006 Author Posted June 29, 2006 Just so everybody benefits, I got about a month out of it. New one coming from Arnott.
