mikern10 Posted May 26, 2006 Share Posted May 26, 2006 I hope someone out there can assist me.... When traveling over bumpier road, I notice that there is a rattle-like noise coming from my upper, driver's side window. It sounds almost as if the window is rattling in the door jam, although I feel no significant movement. It is a bothersome noise only because it occurs directly in my left ear.... Also, the problem may be worse after it rains, although that may be my imagination.... I have tried placing my fingers between the weather stripping and the window to alleviate the noise, and it is marginally helpful. Has anyone had a similar problem and know of a solution? Thanks in advance! Mike Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted May 26, 2006 Share Posted May 26, 2006 common problem with the RX series, whether with the rx300 or the rx330. nothing you can really do about it, just gotta live with it. Take it up with ur dealer next time and they might try isolating the problem and adding more padding. Quote Link to comment Share on other sites More sharing options...
