JonJon Posted April 14, 2006 Share Posted April 14, 2006 I have a 1998 Gs400, The Ac Keep shut-in Off, the Ac Light keep blinking... after hitting ac button agian. bout 1 min Ac shut off agian.... Fan is still blowing.. but no AC..sometime about 20-30 trys.. it work.. nice coold Ac... still on.. after I start the car agian.. same thing agian... please help.. it gettin hot in here! Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted April 14, 2006 Share Posted April 14, 2006 Check your climate control unit for codes. See the link below. Look here at this previous thread. Your problem may have a different cause than that in the indicated thread, but you can perform the diagnostic procedure and perhaps get an idea of what's causing your problem. Quote Link to comment Share on other sites More sharing options...
JonJon Posted April 14, 2006 Author Share Posted April 14, 2006 okay, after doing the testing.. tnks for the info by the way.. it show me a code for 21 and 24 .. according to the chart it has something to do with the solar sensor and A/C hardness.. So .. the question is should I take this in to a dealer or it can be a easy fix by myself... Quote Link to comment Share on other sites More sharing options...
mehullica Posted April 14, 2006 Share Posted April 14, 2006 Codes 21 and 24 are normal if you checked for codes while not in direct sunlight. Those 2 codes will go away if you check codes in direct sunlight. Sounds like the compressor is seizing. Quote Link to comment Share on other sites More sharing options...
