S430 Radio Removal
awharton
Hi Guys.
I am intending to fit a bluetooth car phone kit to my SC430, but need to connect the radio mute wire to the radio.
Has anyone removed the radio - is it easy to do? - and does anyone know if the radio has a radio mute input?
Cheers.
This is not an easy job you might break your air controller unit. Remove the center cluter, there are two bolts that the hold the radio unit together on the bottom. This is the hardest part, try to pull out your air controller unit. It will come out but you have to be really carefull. Once you get it out. There are two more bolts on the top. Remove your radio head unit and DON'T SCRATCH THE DASH. Good luck. :magic:
JPI
  • 1 year later...
