annetteg Posted March 19, 2006 Share Posted March 19, 2006 When I press down on the gas petal of my 2002 3e300, sometimes it feels stiff or that there is a pressure resistance. What could cause this Quote Link to comment Share on other sites More sharing options...
steviej Posted March 19, 2006 Share Posted March 19, 2006 Toyota/Lexus design. Many of us 2002+ owners have initially commented on it. You get used to it. Of course this I am saying this without trying your gas pedal. I noticed it was stiffer than my previous car but uniformly and consistently stiffer. It wasn't a stiffness that varied from day to day. If yours does, then get it looked at, something maybe binding it. steviej Quote Link to comment Share on other sites More sharing options...
Proteus503 Posted March 19, 2006 Share Posted March 19, 2006 I had a similar problem with my tacoma, but it didnt start until about 100k miles. Turned out to be a build-up of gunk in the throttlebody (originating from the PCV valve, which is normal). A light mist of throttlebody cleaner (acetone) and a swab with a q-tip and the problem disappeared. good luck! Quote Link to comment Share on other sites More sharing options...
annetteg Posted March 19, 2006 Author Share Posted March 19, 2006 I had a similar problem with my tacoma, but it didnt start until about 100k miles. Turned out to be a build-up of gunk in the throttlebody (originating from the PCV valve, which is normal). A light mist of throttlebody cleaner (acetone) and a swab with a q-tip and the problem disappeared. good luck! Is the Throttle Body visiable or do you need to remove some parts? Quote Link to comment Share on other sites More sharing options...
