sc44000 Posted March 14, 2006 Share Posted March 14, 2006 I have a 1993 lexus sc400 with gold package_allso called the beast by my frends, ok back to the car, the problem I'am having is when i put power steering fluid in it the power steering fluid leeks out on the ground, but most power steering problems do that... but the crazy thing i don't understand is that, white like smoke is comming from out the exhaust at the rear dual pipes, i think it has somthing to do with the power steering fluid i just put in it becouse when the power steering fluid has all leaked out there is no more white like smoke comming from my dual exhaust pipes so i have to drive with out power steering and fluid until i can get the right fix for it, so can you all help me please???!?..thanks Quote Link to comment Share on other sites More sharing options...
bigmalik00 Posted March 18, 2006 Share Posted March 18, 2006 I have a 1993 lexus sc400 with gold package_allso called the beast by my frends, ok back to the car, the problem I'am having is when i put power steering fluid in it the power steering fluid leeks out on the ground, but most power steering problems do that... but the crazy thing i don't understand is that, white like smoke is comming from out the exhaust at the rear dual pipes, i think it has somthing to do with the power steering fluid i just put in it becouse when the power steering fluid has all leaked out there is no more white like smoke comming from my dual exhaust pipes so i have to drive with out power steering and fluid until i can get the right fix for it, so can you all help me please???!?..thanks your power steering set up has nothing to do with the exhaust smoke....you need to fix that leak.. I had the same problem during the month of Jan... sent you a PM Quote Link to comment Share on other sites More sharing options...
Shadow Posted March 23, 2006 Share Posted March 23, 2006 A bad power steering air bypass valve will allow PS fluid to enter the intake and burn giving out blue-ish smoke. Quote Link to comment Share on other sites More sharing options...
JtathBSC400 Posted March 24, 2006 Share Posted March 24, 2006 What Shadow said..... The hose is a small vac type hose that connects to the front of the top of the intake manifold.... Mine was doing that and I pulled the hose off and the car instantly started to miss and died. But if youve got white smoke that might be a different issue, possibly a bad head gasket. Quote Link to comment Share on other sites More sharing options...
