Hi to all,
I have a set of 255/65/16 tires left over from my truck. Does anybody know if they will fit my wifes 2001 RX front wheel drive.
Thanks
Kris
255/65/16 series tires will probably not fit within the rear wheel wells due to the extremely tight space allowed under the rear shocks and springs. 235 is probably about as tight as you can push it. Go take a look above your rear wheels and you'll see exactly what I'm referring to.
a quick search on tirerack.com shows the only sizes they suggest are:
225/70-16 225/65-17 235/55-18 245/50-19 245/45-20
sj
