Just wondering if any of you guys have actually had you valves checked or adjusted. Has anyone seen any problems from not doing so? Let everyone know if even if you have not in order to get an idea how often this is done. I have 95K on mine and I've never had it done. Thanks.
Mine need adjusting across the engine, but only because over 1/2 of my lifter buckets were mixed up during a rebuild. If they need adjusting, it's from lobe, shim, and spring wear. They'll tick when they are much further out than the specification. You'll hear it, it's not something you're going to miss.
It takes a good amount of time to do every valve, but all you need is a screwdriver, some pliers, a set of feeler gauges & a caliper.
