Maintenance For 95 Ls400
Sweet95LS400
I want to say thanks to everyone for all of the wonderful DIY info on this site. I have found it all to be very helpful and hopefully save myself some money doing some of these maintenance items myself. Plus when you do it yourself sometimes, you know it was done right.
I was looking on the lexls.com site and was wondering if many of the procedures for the 1st generation LS the same as the second? I wanted to change my transmission fluid and filter, power steering fluid, and transmission mount and have found great write ups for those things. But wasnt sure if they were the same for my 95 or not. Can anyone lend me some advice?
Thanks!
Thanks!
I've done on my 95 ls400 all these maintenance almost same as 91 ls400, here are something I think you should be carful to do:
1: Get your transmission fluid from your local lexus dealer, you don't need change your transmission filter,it is a metal one, you just need to clean it. But be very carfull when you want to take off the transmission drain pan,it is very hard to break it free, don't make the edge of pan uneven,also carefully clean the old sealer, I clean the filter with brake cleaner, before you install the filter back, make sure it is abslutly clean, not water,no brake cleaner at all, otherwise it may polution the transmission fluid I think. I brought a new gasket, part #35178-50010, and do as this guide you: http://www.lexls.com/tutorials/transmission/transchange.html
2:My power sterring runs good, so I don't flush my power sterring fluid, I just partial replace them with new Dox-III ATF fluid as manual suggested , each time I just pump half quart old fluid from reservoir and add new one, repeat many times until the color becomes red. If you want to flush the whole system, it is much better than I do.
3:I have switch to synthetic oil, it is no problem at all.
4:Clean MAF sensor located between main air intake and throttle body with electirc contector clean spray,do not use brake cleaner or oil cleaner! and also clean the throttle body as guide here http://www.lexls.com/tutorials/EFI/throttlebody.html.
5: I have change my ten years old fule filter last year.this was done in a local car shop, because I am little worrid about the gas dangerous.
That all what I do on my 95ls400 last year
Hope you have nice ride.
The gasket you referenced #35178-50010 is for the drain plug itself. Do you have a part number for the actual gasket around the pan?
Also, I know with my Honda's before when you changed the oil they had a "crush" washer that needed replaced each time the oil drain plug was removed. Does anyone have a part number for this?
I found the package of gasket for pan , it is made by FEL-PRO,parts #: 94206 Automatic Transimission Oil Pan gasket
and also check this : http://www.rockauto.com/catalog/catalog.ph...2&parttype=8612
I brought it from my local auto shop in Canada
