Part #48674-50030 is the strut bushing which comes with the mount so we are back to square one again. We are trying to get the bushing only without the mount but it doesn't look promising.
Again if you look at the pictures I took last night and looking at it in person, I don't think there is a way to "press" a bushing out. It was designed to be replaced as a whole, excluding the rod.
After waiting on parts to arrive I have now gotten to the driver's side of the front suspension. The strut bar bushing on the driver's side is definitely cracked and in bad shape.
I wonder if this is the reason that the alignment shop told me they could not pull in the proper caster on the driver's side?
Have ordered these bushings for both sides at $103.00 a piece. Replacement can be done with the strut bars installed. Only requires removal of 3 nuts in the wheel well area and a large nut on the front side of the strut bar behind the plastic belly pan.
