I have a 2000 RX300 that the clock has started resetting to 1:00 when I start the car after a cold night. I thought it sounded like something that would happen if the battery is getting low. I called the service dept at Lexus dealership (120 miles away) said they said it probably is the battery. However, a local Goodyear service center ran a check on the battery and the alternator and both checked out okay. Has anyone else had this problem or have any ideas?
You need a new battery
The battery checked out good. Have you had this problem? I haven't had a problem since the battery was checked, but have only had one cold night since. I thought maybe something was loose and gotten tightened when battery was checked. ???
For the 15-20 other people who also posted this exact same problem ,once the battery was changed it was rectified.
Search for there posts for more info
Let me add a new area to look at. Ground Hog Day? You know, every day is the same until you do something good?
Gary
way to go Steelers
