Timing Belt On 2000 Rx 300
2000RX300
you don't hafta remove the water pump unless you're going to replace it. that being said, most people just opt to replace the water pump the same time they do timing belt because they're already in there at that time and it's probably worth it to just do it all in one shot unless you enjoy paying for the labor again ;)
Just wondering in order to do a timing belt change on the 2000 RX 300, does it require removal of the water pump? Also can anyone recommend a good indy mechanic in Atlanta.
