ski5er Posted January 24, 2006 Share Posted January 24, 2006 Thanks for your help so far. To get the Brake Light indicator off I am replacing the 4 lights and the 1 center bulbone at a time. I've done all but the lights located on the hatch door. I see the two nuts to remove but is there more to remove behind the fuzzy back panel and how do I get that off? Quote Link to comment Share on other sites More sharing options...
liqrsicc Posted January 24, 2006 Share Posted January 24, 2006 Thanks for your help so far. To get the Brake Light indicator off I am replacing the 4 lights and the 1 center bulbone at a time. I've done all but the lights located on the hatch door. I see the two nuts to remove but is there more to remove behind the fuzzy back panel and how do I get that off? yeah, you need to get that fuzzy panel off. you can use a panel popper. i just use my finger and pry it off. Quote Link to comment Share on other sites More sharing options...
