bluedevil Posted January 22, 2006 Posted January 22, 2006 I have not found another reply to this issue for someone's 95 CD Changer. I have a '98 GS300 and the changer is hung. Radio plays fine but the changer will not eject. Force has not worked so far :) Does anyone know if removing the radio fuse will allow the changer to be removed manually? Any suggestion(s) is greatly appreciated. Frustrated
dcfish Posted January 22, 2006 Posted January 22, 2006 I have not found another reply to this issue for someone's 95 CD Changer. I have a '98 GS300 and the changer is hung. Radio plays fine but the changer will not eject. Force has not worked so far :) Does anyone know if removing the radio fuse will allow the changer to be removed manually? Any suggestion(s) is greatly appreciated. Frustrated You can reset the changer by disconnecting the neg. battery cable for a few minutes, Or pull the fuse. When you reconnect the battery you should hear the changer reset. Then try to reject.
