overdose007 Posted January 9, 2006 Share Posted January 9, 2006 How do you change the brake lights that seat in the rear window in a 1995 lexus ls 400. My brake light came on and i checked on the brake lights and had someone stand behind my car when i pressed on the brake and it is the brake light that is atop the rear seats behind the rear window. Thanks. Quote Link to comment Share on other sites More sharing options...
ko90ls Posted January 9, 2006 Share Posted January 9, 2006 if the subwoofer is still in there then there should be some clips on both sides that secure the cover. by removing them you should be able to change the lights Quote Link to comment Share on other sites More sharing options...
wwest Posted January 9, 2006 Share Posted January 9, 2006 By the book cover the end of a flat blade screwdriver with masking or duct tape so as not to scratch anything and pry the brake light cover up, carefully but firmly, with the screwdriver end. Quote Link to comment Share on other sites More sharing options...
