Es250 Woodgrain Panel Removal
bob95603
Trying to take out the woodgrain heater/ac control & radio panel to put in a radio. Pryed off the top of the clock panel, but there seems to be a tensioner or spring holding the bottom of the piece. I was thinking that it was just held on with clips, but this sucker just won't detatch on the bottom. Has anyone done this? Do I need to go in thru the glovebox and disassemble part of the dash?
Just found the answer at http://www.carstereohelp.com/stereoremovalLexusES250StrR.htm
Edited by bob95603
lift up the piece in the center console, its holding the piece with the radio and everything in. then grab a screwdriver and CAREFULLY pry out on the sides fo the HVAC panel, it should pop out enough for you to slide upwards and remove it.
beware the plugs connected to the center console piece though.
Edited by ArmyofOne
