sursmokeal0t Posted January 3, 2006 Share Posted January 3, 2006 can someone tell me how to take apart my nav screen... i need to so i can get to the back plugs... Thanks in advance Quote Link to comment Share on other sites More sharing options...
zube Posted January 3, 2006 Share Posted January 3, 2006 pry out vents above nav sreen start on left then goto right there are 2 plugs one for clock one for hazards unplug set vent aside. There are 2 10 mm bolt behind vents. Use a hook tool to get up behind the ash tray and pull it towards you. There one plug for the cigarette lighter unplu and set it aside. There is two more 10 mm bolts. You will notice to the left of the bolt in the bottom right hand corner there is a black plug remove that and the whole radio should come right out. Use towels to lay on the console so you dont scratch anything. Quote Link to comment Share on other sites More sharing options...
sursmokeal0t Posted January 6, 2006 Author Share Posted January 6, 2006 Thanks for your input... Greatly appreciated Quote Link to comment Share on other sites More sharing options...
