jjewell Posted December 31, 2005 Share Posted December 31, 2005 Thats my sons description & I have to agree. Not really horrible but noticeable when going over minor or worse bumps in the road. I did the visual and "grab & shake" test of everything I could see- no luck. It doesn't appear with the rear end (bumper) bounce test either. Tried to prevent the :chairshot: by doing a search but didn't really find anything other than bushings. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted December 31, 2005 Share Posted December 31, 2005 I think the bushings are a good possibility. ;) Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted December 31, 2005 Share Posted December 31, 2005 (edited) I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. Edited December 31, 2005 by ArmyofOne Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted December 31, 2005 Share Posted December 31, 2005 (edited) I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. GOT IT. its called a lateral arm. those bushings are bad. #'s 2, and 1 have bushings in those far holes. those are bad. Edited December 31, 2005 by ArmyofOne Quote Link to comment Share on other sites More sharing options...
jjewell Posted December 31, 2005 Author Share Posted December 31, 2005 I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. GOT IT. its called a lateral arm. those bushings are bad. #'s 2, and 1 have bushings in those far holes. those are bad. Once again you come thru. You must be my Lexus guardian angel! THANKS!!! Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted December 31, 2005 Share Posted December 31, 2005 I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. GOT IT. its called a lateral arm. those bushings are bad. #'s 2, and 1 have bushings in those far holes. those are bad. Once again you come thru. You must be my Lexus guardian angel! THANKS!!! If thats not it, check your rear knuckle bushings. but im pretty sure thats it. it sounds like a series of thuds coming from the trunk as you turn or hit a rough road right? Quote Link to comment Share on other sites More sharing options...
jjewell Posted December 31, 2005 Author Share Posted December 31, 2005 I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. GOT IT. its called a lateral arm. those bushings are bad. #'s 2, and 1 have bushings in those far holes. those are bad. Once again you come thru. You must be my Lexus guardian angel! THANKS!!! If thats not it, check your rear knuckle bushings. but im pretty sure thats it. it sounds like a series of thuds coming from the trunk as you turn or hit a rough road right? Yes, low tone multiple thuds, just like the sound of golf balls bouncing in the trunk. Quote Link to comment Share on other sites More sharing options...
ArmyofOne Posted December 31, 2005 Share Posted December 31, 2005 I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. GOT IT. its called a lateral arm. those bushings are bad. #'s 2, and 1 have bushings in those far holes. those are bad. Once again you come thru. You must be my Lexus guardian angel! THANKS!!! If thats not it, check your rear knuckle bushings. but im pretty sure thats it. it sounds like a series of thuds coming from the trunk as you turn or hit a rough road right? Yes, low tone multiple thuds, just like the sound of golf balls bouncing in the trunk. yep, more than likely, these are your culprits. i could be wrong, im not a god LOL. but thats what was causing mine. get the bushings for the camry, they are cheaper and they same bushing, just paying for the Lexus name adds $7 to the price. Quote Link to comment Share on other sites More sharing options...
jjewell Posted December 31, 2005 Author Share Posted December 31, 2005 I think the bushings are a good possibility. ;) thats exactly what it is. there are 2 buchings on the long control arms in the ES250's rear end. these are called trailing arms. where they connect in the center, under the back seat, the pivot point. those are bad. cost like $10 for the pair and will take like an hour to change its a pretty straightforward procedure. good luck. mine had this problem too. GOT IT. its called a lateral arm. those bushings are bad. #'s 2, and 1 have bushings in those far holes. those are bad. Once again you come thru. You must be my Lexus guardian angel! THANKS!!! If thats not it, check your rear knuckle bushings. but im pretty sure thats it. it sounds like a series of thuds coming from the trunk as you turn or hit a rough road right? Yes, low tone multiple thuds, just like the sound of golf balls bouncing in the trunk. yep, more than likely, these are your culprits. i could be wrong, im not a god LOL. but thats what was causing mine. get the bushings for the camry, they are cheaper and they same bushing, just paying for the Lexus name adds $7 to the price. Excellent! I was hoping there was a Camry equivalent! Thanks again!!! Quote Link to comment Share on other sites More sharing options...
