mark.blend Posted December 31, 2005 Share Posted December 31, 2005 Could some explain - what is the sequence to programming a key, for 1995 SC 400. I just bought this car and the key works everything, except the auto buttom lock. I have replaced the battery, but It did not help. Thanks, mark.blend Quote Link to comment Share on other sites More sharing options...
Marty Witt Posted January 3, 2006 Share Posted January 3, 2006 Open driver door, keep it open and in the unlocked position Put original key in ignition and pull out Lock and Unlock the doors 5 times Close the door and open the door Lock and Unlock the doors another 5 times Put the Master Key in the ignition, turn it on and then off and remove from the ignition You should hear a confirmation beep within 10 seconds and the door locks should actuate Push the button on the new key Close the door and open the door Push the button again on the new key good luck Marty Quote Link to comment Share on other sites More sharing options...
mark.blend Posted January 4, 2006 Author Share Posted January 4, 2006 Open driver door, keep it open and in the unlocked position Put original key in ignition and pull out Lock and Unlock the doors 5 times Close the door and open the door Lock and Unlock the doors another 5 times Put the Master Key in the ignition, turn it on and then off and remove from the ignition You should hear a confirmation beep within 10 seconds and the door locks should actuate Push the button on the new key Close the door and open the door Push the button again on the new key good luck Marty Open driver door, keep it open and in the unlocked position Put original key in ignition and pull out Lock and Unlock the doors 5 times Close the door and open the door Lock and Unlock the doors another 5 times Put the Master Key in the ignition, turn it on and then off and remove from the ignition You should hear a confirmation beep within 10 seconds and the door locks should actuate Push the button on the new key Close the door and open the door Push the button again on the new key good luck Marty Marty, I appreaciate the help - I programmed through the sequence and received the conformation beeps; however, the button does not respond. Please advise, Mark Quote Link to comment Share on other sites More sharing options...
Marty Witt Posted January 6, 2006 Share Posted January 6, 2006 Sorry big guy, that's all I know!!! Can someone help this guy!!! Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 6, 2006 Share Posted January 6, 2006 Sorry big guy, that's all I know!!! Can someone help this guy!!! I will look further, But I think this will work, 96_key_fob.pdf Quote Link to comment Share on other sites More sharing options...
tanline Posted May 22, 2007 Share Posted May 22, 2007 Sorry big guy, that's all I know!!! Can someone help this guy!!! I will look further, But I think this will work, The pdf manual linked above works for me - I have a 1997 SC 400... Be sure to follow it exactly as written - should take you no more than 10 seconds Thanks dcfish! Quote Link to comment Share on other sites More sharing options...
dcfish Posted May 22, 2007 Share Posted May 22, 2007 Sorry big guy, that's all I know!!! Can someone help this guy!!! I will look further, But I think this will work, The pdf manual linked above works for me - I have a 1997 SC 400... Be sure to follow it exactly as written - should take you no more than 10 seconds Thanks dcfish! No problem, Just want to help out fellow lexus owners keep there cars up to snuff. Quote Link to comment Share on other sites More sharing options...
dcfish Posted May 22, 2007 Share Posted May 22, 2007 Sorry big guy, that's all I know!!! Can someone help this guy!!! I will look further, But I think this will work, The pdf manual linked above works for me - I have a 1997 SC 400... Be sure to follow it exactly as written - should take you no more than 10 seconds Thanks dcfish! No problem, Just want to help out fellow lexus owners keep there cars up to snuff. Here is a key transponder application guide for all to use. Enjoy!!! key_transponder_application_guide.pdf Quote Link to comment Share on other sites More sharing options...
