jayneb81 Posted December 21, 2005 Share Posted December 21, 2005 I have a 92 SC400 (just bought it, 197K on it) and it's always run fine up untill last night. I started it up, put it in reverse, and then I noticed that I was moving very sluggishly. I looked down and that "Engine" light was flashing. I put the car in park, turned it off, then restarted it and it drove home just fine. It did it again today after I pumped gas and went to start the car, and I did the same thing again to re-start it. Could anyone PLEASE let me know what this could possibly be and how to correct it? Thank you so much. Quote Link to comment Share on other sites More sharing options...
kcpth Posted December 22, 2005 Share Posted December 22, 2005 There is a simple procedure u can do the next time ur check engine light comes on. It requires like a small piece of wire.... maybe around an 18Gauge wire... about 4inches will do. Strip both ends of the wires... about 1/2 inch. Since ur engine is an OBDI then u can do it urself without going to Autozone n asking them to read the trouble code for u. By the way... Autozone wont' read any OBDI... they only do OBDII. Here is a website that will explain how to check the trouble code in details. http://uktoyotaestimasite.tripod.com/obdcodes.htm#obtaincode http://www.troublecodes.net/Lexus/ The 2nd website is also a good one. It has a list n tells u wut each of the codes means. Make sure u do it correctly. Dont accidentally misjump the wrong ones.... i dont know wut will happen... but u better not risk it. Just print the picture out.... n align wut u see under the diagnostics n the picture together... then u can find the right ones. O... it's under the hood by the way. Do as what the website suggests.... n remember to count it. At first i was a bit nervous doing it....but it is actually quite simple. When u count it... n ur still not sure wut that suggests... then come back to the forum n post the trouble code that u got on here. Im sure someone will b able to further help u. N welcome to the club ;) Also Jayne... there can be many things that can attribute to this. Check the engine code... n let us know. Have u done n e thing recently that may have contributed to this? It's hard to say what the problem is... we just have to trouble shoot. Good luck. B) Quote Link to comment Share on other sites More sharing options...
