This pertains to 1993 GS300. After a snow storm and lots of Traction Control activation, the amber TRAC light now comes on after about 5 minutes of driving, and stays on (dry roads). I read the similar thread for a 1994 GS300, and I followed the instructions on diagnosing the problem. The brake fluid reservoir was pretty much full, but I added more and drove it and the TRAC light still comes on, so I figure that can't be the problem.
Next, I pulled the "Short Pin" in DL1 (under hood). I put a jumper between Tc and E1 of DCL2 (under steering wheel). Turned ignition to ON and the following lights flashed.
The little red "airbag picture" warning light flashed ON/OFF constantly. The red "Cruise" warning light flashed ON/OFF constantly. The amber "ABS" warning light flashed 5 times.. pause.. 4 times. The amber "TRAC" warning light flashed 4 times.. pause.. 3 times.
I'm confused on what this means as the ABS Diagnostic Trouble Code Chart that I found on Lexus Forums didn't have that combination of lights for both the ABS light and the TRAC light.
I should add that I turned the Traction Control system off (dash button) and the TRAC light still comes on after about 5 minutes of driving.
Can anyone advise on what I need to check/replace next?
Thanks for any help on this.
Seems like the flow chart is pointing to the accumulator. This would be the canister that holds the pressurized brake fluid until it is needed by the brake system. They can leak internally allowing the pressure to bleed down in a short time, in turn, causing the pump to run too often.
  • 2 years later...
I'm having the exact same symptoms with my '95 GS300. Is it possible to just disconnect the TRAC system and still operate the car safely? I have no idea how to replace the accumulator.
I hope this helps out for you guys with the frist gen gs300! it hard to get help around here!!!
Engine OBDI Diagnostic Codes
The list below will tell you where the problem lies but will not go into diagnosis. Please consult your repair manual for in depth diagnosis, testing and troubleshooting.
12 - RPM signal no. 1
13 - RPM signal no. 2
14 - Ignition no. 1 signal
15 - Ignition no. 2 signal
16 - ECT control signal
17 - No. 1 cam position sensor signal
18 - No. 2 cam position sensor signal
21 - Main oxygen sensor signal (on left bank)
22 - Water temp sensor signal
24 - Intake air temp. sensor signal
25 - Air-fuel ratio lean malfunction
26 - Air-fuel ratio rich malfunction
27 - Sub-oxygen sensor signal (on left bank)
28 - Main oxygen sensor signal (on right bank)
29 - Sub-oxygen sensor signal (on right bank)
31 - Air flow meter signal
35 - HAC sensor signal
41 - Throttle position sensor signal
43 - Starter signal
47 - Sub-throttle position sensor signal
51 - Switch condition signal
52 - No. 1 knock sensor signal
53 - Knock control signal
55 - No. 2 knock sensor signal
71 - EGR system malfunction
Transmission OBDI Diagnostic Codes
42 - No. 1 speed sensor signal malfunction
46 - Open or short circuit in no. 4 solenoid valve
61 - No. 2 speed sensor signal malfunction
62 - Open or short circuit in no. 1 solenoid valve
63 - Open or short circuit in no. 2 solenoid valve
64 - Open or short circuit in no. 3 solenoid valve
67 - OD direct clutch speed sensor signal malfunction
68 - Short circuit in kick-down switch
Air Bag OBDI Diagnostic Codes
11 - Short in squib circuit or front airbag sensor circuit (to ground)
12 - Short in squib circuit or front airbag sensor circuit (to +B)
13 - Short in squib circuit (between D+ wire harness and D- wire harness)
14 - Open in squib circuit
15 - Open in front airbag sensor sensor circuit
22 - Airbag warning light system
31 - Center airbag sensor assembly malfunction
41 - Malfunction stored in memory
ABS OBDI Diagnostic Codes
11 - Open circuit in ABS solenoid relay circuit
12 - Short circuit in ABS solenoid relay circuit
13 - Open circuit in pump motor relay circuit
14 - Short circuit in pump motor relay circuit
21 - Open or short circuit in 3-position solenoid circuit for front right wheel
22 - Open or short circuit in 3-position solenoid circuit for front left wheel
23 - Open or short circuit in 3-position solenoid circuit for rear right wheel
24 - Open or short circuit in 3-position solenoid circuit for rear left wheel
31 - Front right wheel speed sensor signal malfunction
32 - Front left wheel speed sensor signal malfunction
33 - Rear right wheel speed sensor signal malfunction
34 - Rear left wheel speed sensor signal malfunction
35 - Open circuit in front left or rear right speed sensor circuit
36 - Open circuit in front right or rear left speed sensor circuit
37 - Faulty front speed sensor rotor
41 - Low battery voltage or abnormally high battery voltage
43 - Malfunction in TRAC control system
51 - Pump motor is locked, Open in pump motor ground
Always ON - Malfunction in ECU
TRAC OBDI Diagnostic Codes
11 - Open in TRAC brake main relay circuit
12 - Short in TRAC brake main relay circuit
13 - Open in TRAC throttle relay circuit
14 - Short in TRAC throttle relay circuit
15 - Electric supply to TRAC motor for a long time (fluid leakage)
16 - Open circuit in pressure switch circuit
17 - Pressure switch remains OFF
19 - TRAC motor ON and OFF operation is higher than a predetermined number of times (accumulator pressure leakage)
21 - Open or short in master cylinder cut solenoid valve circuit
22 - Open or short in accumulator cut solenoid valve circuit
23 - Open or short in reservoir cut solenoid valve circuit
24 - Open or short in sub-throttle actuator circuit
25 - Step motor does not move to a position decided by ECU
26 - Sub-throttle valve does not move even when the sub-throttle valve is controlled to fully open position by ECU
27 - When power supply to step motor is stopped, sub-throttle valve does not reach its fully-open position
44 - During TRAC control, NE signals are not input to the ECU
45 - When idle switch is ON, main throttle position sensor signal is 1.5V or higher
46 - Main throttle position sensor signal is 4.3V or higher, or main throttle position sensor signal is 0.2V or lower when idle switch is OFF
47 - When idle switch is ON, sub-throttle position sensor signal is 1.45V or higher
48 - Sub-throttle position sensor signal is 4.3V or higher, or sub-throttle position sensor signal is 0.2V or lower when idle switch is OFF
49 - Open or short in engine communication circuit
51 - Problem in engine control system
52 - Brake fluid level warning switch ON
54 - Open in TRAC motor relay circuit
55 - Short in TRAC motor relay circuit
56 - TRAC pump motor locked
nice post.... :) your right somedays it can be VERY hard to get help around here as some of the OG's act like they to good to post on some peoples topics and no not just mine. i decided to give up on it, i post to help people so i still stick around but as you can tell from my other posts, i have really moved on to a more helpful place. but again very nice post. i left out all the details so i didnt clog this post
