droppedlexus Posted December 16, 2005 Share Posted December 16, 2005 1993 lexus gs300, my center console will not turn on......clock will not turn on, heat and a/c will not turn on, the only thing that works is my hazard lights....I have a aftermarket cd player in my car the cd player will not turn on but the electronic face plate does go up and down, but no lights on the cd player....any idea, it's cold here today so help please Quote Link to comment Share on other sites More sharing options...
skenn1977 Posted December 16, 2005 Share Posted December 16, 2005 Is the transmission locked? What about windows, locks, and exterior lights. I lost all of that a week ago, but the engine would run. It ended up needing a new alternator. Quote Link to comment Share on other sites More sharing options...
droppedlexus Posted December 17, 2005 Author Share Posted December 17, 2005 Is the transmission locked? What about windows, locks, and exterior lights. I lost all of that a week ago, but the engine would run. It ended up needing a new alternator. no everything works like normal.....it's strange because this morning the heat radio and clock did not work, when I came out this afternoon they where working fine, but now when I step on the brake my radio pops a little and my clock dims??????? Quote Link to comment Share on other sites More sharing options...
deadmilenko Posted December 17, 2005 Share Posted December 17, 2005 Did you check all of your fuses? There are some located in the driver's and the passenger's side front kick panels behind the black doors. Check your wiring harness under the hood and under the dash for burnt wires. If no luck there you need to try to reset the ECU by disconnecting the neg. battery terminal. Then reconnect if after a couple of minutes. Or you may have a bad alternator. Get that checked too. Quote Link to comment Share on other sites More sharing options...
