Ellasimone Posted December 7, 2005 Share Posted December 7, 2005 How do you turn off the tire pressure monitoring light if you change rims on the 2006 GS 300? Please email the info to Crawfordgroup@comcast.net Quote Link to comment Share on other sites More sharing options...
Ed S Posted December 8, 2005 Share Posted December 8, 2005 How do you turn off the tire pressure monitoring light if you change rims on the 2006 GS 300? Please email the info to Crawfordgroup@comcast.net ← There is a recessed button under the front passenger side dash. The button resets the tire presure system for different size tires. Quote Link to comment Share on other sites More sharing options...
Ellasimone Posted December 8, 2005 Author Share Posted December 8, 2005 The button under the dash resets the light if the pressure changes in the tires. The sensor for the system is located in the valve stem 0f the factory rim. when you put custom wheels on the car you in effect destroy the link because the sensor is gone. The warning light constantly stays on because it cannot detect the sensor in the valve stem. Now how do you disconnect the warning light? Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 8, 2005 Share Posted December 8, 2005 Pull the fuse? Quote Link to comment Share on other sites More sharing options...
