:unsure: Hi there... First time here. I have obtained a Sensor Signal Modification chip and I'm trying to find out if anyone out there has installed one of these. It needs to be inserted as close to the ECU as possible on the IAT sensor wire. Any suggestions? How about a wiring diagram so I don't screw this up? Or are these things even worth the hassle?
it would not make a difference where you put it
but i don't know of anyone who has done it
i think it is a peice of !Removed!
i talked to the guy and am still waiting to see a proper dyno chart
in dyno viewer format 4 weeks later
as the dyno sheets can be made to show better hp and torque by changing the altitude and otehr variables
take it for yourself as to wy he hasn't answer
i think the one guy on ebay is also from toronto
but said he does not do pick ups?
what the hell is up with that?
