Trac Off Blinking
overdose
I just got my starter replaced and then the trac off indictor started flashing on my dash and the trac off button by the shifter is not working (or at least not lighting up). When i try to drive it, 30 mph is top speed at 4-5000 rpms, it feels like it is stuck in first gear and will not get out. any help would be much appreciated. i have a 1995 ls 400
Did you tell your mechanic to disconnect the battery for a few minutes like RF said? If not, then do this first before you mess with anything else!!
Could be an O2 sensor failure... happened to me once. Ask your mechanic to check O2 sensors.
