My uncle is the proud owner of a 98GS300. Well I will be installing a gps sytem for him that requires tapping into the the VSS wire(speed sendor) which I can only assume is for destination arrival calculations. Anywho I am hoping that someone knows where the wire is located in the car and its colo coding??
No need to post the same topic twice.:wacko:
http://www.albinoblacksheep.com/flash/posting.php
Sorry I noticed I had created the 1st post in the wrong forum, figured thats why I had'nt got any replies
If I am not mistaken it is pin #10 on the IL3 connector in the attached file. Let me know if this helps. I think the wire color is either blue or violet/ white, I don't want to mislead you so look at the # 10 pin wire to confirm.
GS_SPEEDSENSOR_WIRE.pdf
SPEED_SENSPO_CONNECTORS.pdf
