gixermann Posted November 24, 2005 Posted November 24, 2005 My uncle is the proud owner of a 98GS300. Well I will be installing a gps sytem for him that requires tapping into the the VSS wire(speed sendor) which I can only assume is for destination arrival calculations. Anywho I am hoping that someone knows where the wire is located in the car and its colo coding??
dcfish Posted November 24, 2005 Posted November 24, 2005 My uncle is the proud owner of a 98GS300. Well I will be installing a gps sytem for him that requires tapping into the the VSS wire(speed sendor) which I can only assume is for destination arrival calculations. Anywho I am hoping that someone knows where the wire is located in the car and its colo coding?? ← No need to post the same topic twice. http://www.albinoblacksheep.com/flash/posting.php
gixermann Posted November 24, 2005 Author Posted November 24, 2005 Sorry I noticed I had created the 1st post in the wrong forum, figured thats why I had'nt got any replies
dcfish Posted November 24, 2005 Posted November 24, 2005 Sorry I noticed I had created the 1st post in the wrong forum, figured thats why I had'nt got any replies ← If I am not mistaken it is pin #10 on the IL3 connector in the attached file. Let me know if this helps. I think the wire color is either blue or violet/ white, I don't want to mislead you so look at the # 10 pin wire to confirm. GS_SPEEDSENSOR_WIRE.pdf SPEED_SENSPO_CONNECTORS.pdf
