Hello, just wanted some advise here. About two months ago, I replaced my lower control arm front with bushing kits as it was cheaper overall, however, the noise and squeeks I get is unbarable. Any advise to fix the problem will greatly be appreciated.
What brand did you use?Were they rubber or polyurathane?If they were Poly,you need to put alot alot alot of lube.
they are poly, but did not do the job myself. I've been told that I need to put some sylicone.
