Options20002001 Posted November 21, 2005 Posted November 21, 2005 Is there a replacement CD changer (or a DVD changer) for 97 LX450 that will fit where the OEM one is located. Is there one that will fit in the glove compartment? What is the favorite aftermarket changer to replace the OEM one? Which is the most likely place it gets installed? Thanks. Options
dcfish Posted November 21, 2005 Posted November 21, 2005 Is there a replacement CD changer (or a DVD changer) for 97 LX450 that will fit where the OEM one is located. Is there one that will fit in the glove compartment? What is the favorite aftermarket changer to replace the OEM one? Which is the most likely place it gets installed?Thanks. Options ← Are you 100% sure that you are going to go aftermarket?
airbison Posted November 21, 2005 Posted November 21, 2005 Is there a replacement CD changer (or a DVD changer) for 97 LX450 that will fit where the OEM one is located. Is there one that will fit in the glove compartment? What is the favorite aftermarket changer to replace the OEM one? Which is the most likely place it gets installed?Thanks. Options ← Go to crutchfield.com and DIY. Good Luck
bong2611 Posted December 7, 2005 Posted December 7, 2005 I changed out everything and installed a DVD player where my CD changer use to be.
