kgh31386 Posted November 21, 2005 Posted November 21, 2005 It's a 93 GS. It just recently got cold, and after I start it up and start driving....it moans when I turn. Then I have another sound I hear when I turn. If I turn the wheel once over, then continue to turn more...it'll make a clank real fast. ANNND one last sound I have is like my brakes squeal when I'm moving about 5-10 mph, but I'm not even applying the brakes half the time it makes that squeal. I need some help.....so help
Abear Posted November 21, 2005 Posted November 21, 2005 The turning sound is your power steering, check the fluid. The second noise I'm not quite sure. The third sound is happening because one of your break pads is really wearing out. I had the same two noises(at least the two I could help you with). Good luck.
ArmyofOne Posted November 21, 2005 Posted November 21, 2005 It's a 93 GS. It just recently got cold, and after I start it up and start driving....it moans when I turn. Then I have another sound I hear when I turn. If I turn the wheel once over, then continue to turn more...it'll make a clank real fast. ANNND one last sound I have is like my brakes squeal when I'm moving about 5-10 mph, but I'm not even applying the brakes half the time it makes that squeal. I need some help.....so help ← DO NOT run that pump when its low on fluid, it will burn up. sounds like it may be gone anyways. if the fuid is not the culprit, check the belt. I dont believe its a serpentine belt on a 93, it should be separate.
