Lexus_gs400 Posted November 19, 2005 Share Posted November 19, 2005 I have my JDM HID kit on my fog lights now, However it makes my orignal HID look dim, I tried ordering 2 others set of hid bulbs only for my headlight, still looks dim ( not bright as the fog lights ). If I change the ballast of the orignal and add aftermarket would I still have the auto leveling from the headlight? And would it make it brighter just like the foglights? Thanks Quote Link to comment Share on other sites More sharing options...
SKperformance Posted November 19, 2005 Share Posted November 19, 2005 If you can wire everything back properly then the auto adjustment will still work but you need to be careful not to stress the motors by improper mounting. The fogs will look brighter as it is a short dispersion and a wide range ,while a headlight focus more down the road so it does not look bright. Quote Link to comment Share on other sites More sharing options...
Lexus_gs400 Posted November 20, 2005 Author Share Posted November 20, 2005 If you can wire everything back properly then the auto adjustment will still work but you need to be careful not to stress the motors by improper mounting.The fogs will look brighter as it is a short dispersion and a wide range ,while a headlight focus more down the road so it does not look bright. ← Thanks Quote Link to comment Share on other sites More sharing options...
