Removing My Oed Hid For Aftermarket Hid Lights
I have my JDM HID kit on my fog lights now, However it makes my orignal HID look dim, I tried ordering 2 others set of hid bulbs only for my headlight, still looks dim ( not bright as the fog lights ). If I change the ballast of the orignal and add aftermarket would I still have the auto leveling from the headlight? And would it make it brighter just like the foglights? Thanks
If you can wire everything back properly then the auto adjustment will still work but you need to be careful not to stress the motors by improper mounting.
The fogs will look brighter as it is a short dispersion and a wide range ,while a headlight focus more down the road so it does not look bright.
Thanks
