Have a 91 LS 400 and everything was going fine with the audio then the CD's just stopped working. I took the CD changer cartridge out to make sure everything was fine. Put it back in and could hear it working. So I am not sure if it is the changer (which is trunk mounted) or the CD button on the audio area of the dash. Is this a common problem?
Sounds like the cd player. If the car had a cell phone it may be installed and the mute got turned on somehow. The mute was in the changer in the early 90s.
Actually the car does have a cell phone built in to the center consol area and there is a small toggle switch by the steering wheel. I wonder if i hit something and didn't realize it. I am not even sure if the phone works or not.
Check into that it is probably the culprit.
Just checked. Don't think it is the problem. The radio will be playing and when push the CD button nothing happens. Probably just a bad deck?
If it is, it doesn't look like the radio deck will come out very easily.
Removing the headunit isn't that difficult, Have the changer tested at a reputable shop, If you need a headunit or changer I have both.
