larryp Posted October 28, 2005 Share Posted October 28, 2005 Yesterday i had the following warning lights come on all at once (and they're still on): 1) Battery light 2) Brake warning light 3) Rear brake lamp failure light 4) Radiator light 5) Oil level light I did a search and found a post with the same problem, but there was no post as to the resolution. I know that coolant level is fine, oil level is fine, and rear brake lights work. I unplugged the battery for about 5 minutes and reconnected to reset the ECU. No change (i lost memory setting for seat and climate, but not radio - do i need to leave unplugged longer?). Have not had battery or alternator tested, but both are about 2 years old. Car is running fine. Any ideas? Quote Link to comment Share on other sites More sharing options...
rahlo1 Posted October 28, 2005 Share Posted October 28, 2005 alternator Quote Link to comment Share on other sites More sharing options...
SKperformance Posted October 28, 2005 Share Posted October 28, 2005 When the systems shut down from low voltage it is usually from the alternator Quote Link to comment Share on other sites More sharing options...
larryp Posted October 31, 2005 Author Share Posted October 31, 2005 It was the alternator. Replaced this weekend. Thanks for the replies! :D Quote Link to comment Share on other sites More sharing options...
