ihateduke Posted October 24, 2005 Share Posted October 24, 2005 I found a post that recommended that you clean the tbi and iac, in order to improve gas mileage. They listed a bunch of other things as well, but they never explained what these two acronyms are or how to clean them. I tried searching, but I got 0 hits, even when I used the exact phrase from the post. Also, just curious, for those of you who have replaced your spark plugs, did you do the cables as well? If so, where did you buy them? Thanks, Chris Quote Link to comment Share on other sites More sharing options...
steviej Posted October 24, 2005 Share Posted October 24, 2005 I found a post that recommended that you clean the tbi and iac, in order to improve gas mileage. They listed a bunch of other things as well, but they never explained what these two acronyms are or how to clean them. I tried searching, but I got 0 hits, even when I used the exact phrase from the post.Also, just curious, for those of you who have replaced your spark plugs, did you do the cables as well? If so, where did you buy them? Thanks, Chris ← Chirs, IAC is short for Idle Air Control valve. TB is usually short for Throttle Body. Try searching on the bold words. steviej Quote Link to comment Share on other sites More sharing options...
