Codes
ozcelsior
I had the car over to a auto electrician this morining and the error code came up as a faulty TPS They tested the TPS a said that it was working fine just to be on the safe side should i Change it any feedback on this problem would be welcomed thanks.
They couldnt get the codes to clear was told to go to lexus dealership to see if they could clear fault.When i spoke to the service manager because my car was not delevered to australia through Lexus he said that lexus would not work on the problem The car itself works fine so i will just order a TPS sensor change it myself
Also do a service on car were we will be changing Timing belt plugs leads rotors distributors servcing the Transmission, Diff .Car still acclerates to redline never stalls off the line doesnot overheat just the TRC & ABS light stay on and sometimes when you restart they will go off and not come back until the next morning.
