Antena Mast Is Stuck
Where does the mast not relesase from?
The car, the housing itself the nylon thread?'
Try and add all the little details to picture what your problem and solution is!
The mast will not pull free from antena housing. I see original has a clip so it cant pull out i am assuming i am fighting that clip but not sure. directions say to soak over night and it should pull right out but "wrong" it comes out almost all the way but stops.It would be to the point where you would feed new mast back into housing. I dont understand how thdirections think that clip is just going to stop doing its job. HELP!!anyone!!
